  1. #33
    I have been thinking about how to design a holder so that you can route dove tails at the end of boards.
    This is not a function I will be using every day, so it should be simple and it should not compromise the machine in other ways.
    I read the thread by EddyCurrent and how he has done it. It looks good and stable and I am sure it works very well.
    However, I don’t want this function to interfere with the precision of the bed, so I am not too happy with the removable plate. Also, for handling, I find it somewhat impractical to have this opening in the middle of the machine. All that is needed is a jig that will hold the work piece in an accurate and repeatable position. So I was thinking of placing it at the end of the machine, as shown in the model. You simply fasten the work piece with one or two clamps. I may have to extend the cantilevers/ rails to get sufficient overhang for the spindle or alternatively reduce the length of the frame, since this machine is already getting fairly large.
Name:	dove tail jig.jpg
  1. BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
    By njhussey in forum DIY Router Build Logs
    Last Post: 13-04-2020, 05:03 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. My new, and first build....comments greatfully received
  4. Help appreciated
    By joncdrl in forum Milling Machines, Builds & Conversions
    Last Post: 17-09-2012, 08:34 PM
